Generic model pattern based - line issue
ginn.gwon
ginn.gwon
hello  -
I'm working on a panel design which i plan to apply on a pattern surface.
a 'profile' family cannot be imported into 'generic model pattern based',
so I've created lines in 'generic model' family and imported the lines into 'generic model pattern based' and created forms.
when I loaded the finished panel design into a project and tried to apply it to a pattern, it failed to generate the model.
It seemed like the project could not read how the 'generic model' lines were nested to 'generic model pattern based' family. So I drew all the profile lines directly on the 'generic model pattern based' and created forms, it worked fine.
I still would not want to give up the convenience of working in 2d views of 'profile' environment. Drawing details in the work plane viewer window is very limiting. Importing DWG is also limiting since it needs to be exploded and set to correct origin point.
a help would be greatly appreciated -
dzanta
if you attach the family file you are working on and perhaps a sketch of what you are trying to accomplish, I can look at it on Monday morning.
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
ginn.gwon
hi - thanks for the reply. I think I found a work around.
I generated full geometry in generic model environment (instead of the lines to create form in pattern based family environment) and made it kind of adaptive by linking parameters to reporting parameters of the pattern based family (width and length of the pattern --> W / L of the imported geometry)
