As the height of the spiral increases so does the twisting that happens at both ends. Would be very nice if this did not happen. How do I stop this twisting to occur?
It's made by having a start and end profile (square in this case) that is being swepped along the Spline Through Points. If this is not the correct method to get the result I'm looking for, please enlighten me 🙂
Select the form and set to Consistent profile (or somthing sounding similar) from the option ribbon.
@itsme.mozzarella wrote:As the height of the spiral increases so does the twisting that happens at both ends.
Because the work planes (on which the Profiles are placed) are twisting. Are you saying you want to keep the Profiles perpendicular/parallel to level? If so, it would be easier to just slice the ends of the twisted Solid Form created with Void Forms that are perpendicular/parallel to level.
Actually, I don't think I read you right. Now it sounds like you don't want the twist. What exactly are you wanting the final form to look like? Got a picture or something?
If you mean Lock Profiles, that is not it. There's also nothing that says Option (or similar) on the ribbon.
This aswell... but more so, I'd like to keep the profiles from rotating. In the picture, the large square has rotated almost 45° and rotates more as the total height increases.
Do not use the start or end points to host your profile. Add a point hosted to the path line the host your profiles to those points. These can then have a parameter for rotation on each point to adjust if needed.
Obviously you cannot use Lock profiles if the profiles are different along the path. I could have not be seeing the image you post in the question.
