Generic annotation family
yes_and_no
yes_and_no
My generic annotation family has a triangle shape and a line to underline whatever we need to emphasize on the sheet (paper space)
Questions:
1.   Although it has reference line on the model, it won't allow me to drag its length manually. (Yes, the ref line set to "weak"). What should I do?
2.   I created new line type AA with thickness to 5, yet when inserted only the style appear as desired "hidden', but the thickness seems to default to 1.
I look all at setting and couldn't find AA, further more to change this thickness.
3.  Surprisingly, the symbol with filled region does work on paper space. I can create some parametric rectangles to achieve filled region effect on paper space when needed. Should this be non-revit and be avoided ? We don't want certain crash or file size increase unnecessarily...
Thx
RDAOU
@yes_and_no
From how it looks like in the image, what you need is a detail components (line based maybe) and not a generic annotation. If you attach the family it would be much easier to check what you have done and the best way to fix it. And no this is not a non-revit practice. This is a simple line based detail item
arq_42
Grip arrows don't exists in generic annotations, afaik.
You could:
Create a Detail item, or insert your generic annotation into the detail item (be careful with the units).
Or
Instead of a generic annotation, change the category to Title Blocks (NOTE! The family will only work on sheets!)
¿Te resultó útil esta publicación? Dale "Me gusta".
¿Tu pregunta fue respondida correctamente? Haz clic en "ACEPTAR SOLUCIÓN".
mari.shimode
Hi @yes_and_no, did the information provided answer your question? If so, please use Accept Solution so that others may find this in the future.
If you still have the issue, please share us a bit more details regarding your question. Thank you.
Mari Shimode
