How to make the dark portion at the bottom view not under shadow effect
yes_and_no
yes_and_no
Hi. How to make the dark portion at the bottom view (template) not under shadow effect and keeping everything else the same ?
Yes, I did untick the sun path and shadow option.
[The subject line of this post has been edited for clarity by Community Manager. Original: Shadow ?]
RDAOU
@yes_and_no
If the element falls within the region where the shadow is casted, you cannot tell Revit to exclude it or the sun to ignore just that element. You could
  1. EITHER play with the sun settings, time, angle...etc and see if you can get to the desirable output
  2. OR on the sheet overlay that portion of the elevation (just the part you do not need shaded)
mari.shimode
Hi @yes_and_no, did the information provided answer your question? If so, please use Accept Solution so that others may find this in the future.
If you still have the issue, please let us know. Thank you.
Mari Shimode
