Generative Design on Revit 2021 Not Showing Results
haziqNUS
Message 1 of 1
haziqNUS
I have encountered issues with Generative Design not showing any results on most occasions, and when it does, I am unsure how I made it work. Reviving this topic because the the solutions to similar topics in the past are no longer relevant, or unanswered.
Product Versions
Revit 2021 ver 21.1.20.44
Dynamo Core 2.6.1.8786
Dynamo for Revit 2.6.1.8850
Generative Design 21.11.1.0
Issue
When running Generative Design, on Randomize or Optimize, the software seems to run fine but there are no results (see image below)
This is from a test script that I am using to find out where the issue originates from. I have referred to the Help Webpage but none of the suggestions seems to apply to me as results are OK when I run the script on Dynamo with the same inputs.
I was wondering if Generative Design is has limited memory which results in incomplete studies or if there is a better way to create my scripts to ensure that Generative Design can work properly.
I have attached my Dynamo Script for others to refer to.
Replies (0)
