Getting the Add-in for Bluebeam 3d Export to show up.
ndeiomaUBJ78
Message 1 of 12
ndeiomaUBJ78
Hello
In Revit 2022.  I have Bluebeam Review on my computer.  I was hoping that this would enable me to export 3D pdf's.  But no 3d interface is showing up in my add-ins.  Can someone direct me to a step by step "How To" for getting this to work?
Nardo
Replies (11)
Message 2 of 12
ennujozlagam
go to 3D view and print?
Message 3 of 12
ndeiomaUBJ78
ennujozlagam, This doesn't bring up any of the 3D options.  This will only print a 2d image of the 3D view.  Bluebeam and Revit can export an actual 3D model of the Revit Model that can be viewed and spun around in PDF viewer programs like Adobe or Bluebeam.
That's what I am looking for.
Nardo
Message 4 of 12
pendean
Community Legend
Community Legend
BLUEBEAM Support is over here (bottom of page) https://support.bluebeam.com/contact/
Message 5 of 12
RSomppi
Have you restarted your computer since installing BB?
It's been a while since I installed BB but I seem to recall having to associate it with the desired programs or at least getting the option to uncheck certain programs and you need to exit the programs during the installation.
Message 6 of 12
EATREVITPOOPCAD
You may have BlueBeam Standard. You need BlueBeam Extreme or BlueBeam CAD to export 3D PDF.
In blue beam click Revu drop down and the About
If it says Standard you are out of luck
If its NOT Standard go to Start -> Blue Beam Administrator and on the Plugins tab check Revit
The definition of insanity is doing the same thing over and over again and expecting different results
Message 7 of 12
RSomppi
I've got standard with 3D export.
[Image removed.]
Message 8 of 12
EATREVITPOOPCAD
That's interesting... My Revit plugin is greyed out in blue beam administrator. When I looked up why - according to blue beam you cant with a standard license....
https://support.bluebeam.com/articles/plugins-grayed-out-in-bluebeam-administrator/
Problem
Plugins are grayed out in the Bluebeam Administrator and can’t be selected.
Causes
The use of plugins requires a license of Revu CAD, Revu eXtreme, or an active trial of Revu. Your plugins may be grayed out because:
Your computer has applications that are compatible with Revu plugins, such as AutoCAD or Revit, but the registered license is Revu Standard.
@RSomppi if you have some magic trick to make it happen - tips will be greatly appreciated
Message 9 of 12
RSomppi
In the administrator, the grayed out programs already have BB plugged it.
Message 10 of 12
ndeiomaUBJ78
I have Bluebeam Revu eXtreme.
Message 11 of 12
EATREVITPOOPCAD
Did you try checking the boxes in Blue Beam Administrator app?
Message 12 of 12
smohare
Observer
Observer
Yes, it works for all the other software. But I have installed the Revit 2024 and it's not shown there. Can you please suggest?
Thanks.
