Once the 3 box massing study is loaded into Revit. How can I edit the resultant Mass(?) like a standard In Place mass ie create mass floors, apply wall by face etc.
Many thanks
Are you asking how to create System Family Floors from Mass Floors or how to create Mass Floors?
Create Mass Floors | Revit Products | Autodesk Knowledge Network
Unfortunately not. I was looking at editing the resutant Mass(?) from the generative "3 Box Massing study" which appears to produce a 3d Mass but I'm unable to add mass floors or apply Wall by Face constructions to the Mass(?). I was wondering if anyone else had generated forms with this study and had been able to subsequently manipulate the resultant Mass.
@Anonymous
That is a DirestShape ...it category is Mass. You cannot use it to create floors and walls in Revit. The DYN graph in that sample file is just a demo so basically one needs to do a little bit of work more on it
Thanks for the heads-up...Can I enquire if anyone has any pointers of what needs to be done to the Graph to create "useable" mass models within Revit? Many thanks.
The Masses placed in the Revit View are three 50-foot squares on the base plane, centered around points. The first point is fixed, and the XY positions of the other two points are defined. Each square is extruded into a solid volume of a specific height. The three volumes are combined into a single volume. The solid volume is intersected with planes at intervals of 10 feet. The resulting geometry is a series of surfaces, and the summed area of those surfaces is the floor area.
Why can't you In-Place Model the Mass? The specific heights are computed for you.
Create an In-Place Mass | Revit Products 2016 | Autodesk Knowledge Network
Considering that the sample file is a demo and the OUTPUT is a Directshape....what would you suggest a user would do when the study is not for rectangular cuboids? would you also remodel the resulting directshape in Revit?
That would kinda kill the purpose of automated generative and computational design...no?
The OP's question is specifically about 3-Box Massing.
Oh! boy! You could have referenced that link rather than copy pasting the content 🙂 anyhow, the resulting output is a Directshape (which is not mentioned in the article you clipped from) ie: not editable in Revit...and the original post was
So my question to you still stands...what would you suggest one does when the study is not for rectangular cuboids, something not too complex a Revolving 3 Box Massing? remodel from scratch in Revit?
Sorry buddy, but I don't understand your question. But this thread, as I understand it, is specifically about the new 3-Box Mass Generative Design Study. Maybe I'm missing something. It happens.
The original question was how to either change the dynamo graph to produce a Mass/InPlaceMass directly or how to convert the DirectShape into a Mass/InPlaceMass
Yes, that's how I understood it as well. You want to "convert" a resulting DirectShape of the 3-Box Mass Generative Design Study to Revit In-Place Mass. What I'm saying is that the resulting DirectShape of the 3-Box Mass Generative Design Study can be modeled in Revit as a In-Place Mass in literally minutes. 50 ft. square Masses are pretty easy to do. Start with 4-sided Circumscribed Polygons. Bada bing.
