Hey
I am working on a project where different houses each have a different elevation because of the site.
I want to have a general plan that shows all of these. Now I have to paste different crop views together in a layout to get said desired plan.
Is there a way to get it without having to make so many different views (associated with the different levels), just to make this plan?
I did also try to play around with the view depth and cut plane, but then it cuts nicely through a window in one house but not in the next... it's kind of frustrating to me, the novice ahah. Seems like I get complicated projects to start with from my boss.
image: Pieced together plan
Solved by wisedrawing. Go to Solution.
Phil and curtis have it, Plan Regions is the answer, it will not take long as you can do multiple plan regions quickly, once you set the first one and set up the view range levels you can copy multiple views over the project floor area and then click through each one and drop the view ranges and cut plane each increment as you go. it does not take long in a methodical fashion. one Plan Region might cover a couple of areas if the levels are not too different and then it will take less time.
I am a bit of a novice too and going through some of these forum posts and pasting something helps me get it all straight in my head
