gap between vertical and slanted coloumn
Message 1 of 17
any body knows how to join between slanted and vertical coloumn ?
There is a gap and it cannot be joined with join geometry .
Replies (16)
Message 2 of 17
ennujozlagam
your file no column attach? thanks
Message 3 of 17
i am sorry here the file
Message 4 of 17
sorry Here is the file
Message 5 of 17
ennujozlagam
just add a reference plane > pick your column > attach top/base. thanks
Message 6 of 17
are they coped? Zero out the coping distance.
Message 7 of 17
thanks a lot... i understand now...
Message 8 of 17
no i have tried with grid line also
Message 9 of 17
ennujozlagam
not grid line. use reference plane to attach. pick your column and set maximum intersection before attach base /top. thanks
Message 10 of 17
how to add ref plane in coloumn ? should i edit the column with edit family ?
Message 11 of 17
it failed
Message 12 of 17
I don't understand what you are trying to do. Some Copperfield sh*t or what?
Message 13 of 17
hi i tried but it failed... what happened? thanks
Message 14 of 17
ennujozlagam
detach and attach your column. thanks
Message 15 of 17
thanks a lot i just dont click maximum intersection...
Message 16 of 17
ennujozlagam
that's good, you got it. thanks 😅😉
Message 17 of 17
RDAOU
@Anonymous
While the suggested method from @ennujozlagam solved the issue, here are a couple of tips
  1. Giving an offset to the vertical column and using join geometry is another way of cleaning out joins
  2. If you properly model/place the columns, using the coping tool is another option to join a vertical column to a slanted one
  3. Slanted columns behave like beams. That being said, instead of slanted columns you could use Beams
