Guys I need to inset a pump in a piping system
3 ANTWORTEN 3
Nachricht 1 von 4
FacebookGroupMember
285 Aufrufe, 3 Antworten
Guys I need to inset a pump in a piping system. Can you help.using Revit 2022.
3 ANTWORTEN 3
Nachricht 2 von 4
Rak.Marcelo
als Antwort auf: FacebookGroupMember
Hi, let me help...first you need to load a family...either you already have a pump family and you use Insert Family option, or you dont have family, but you can load one which already comes with the Revit using Systems--->Mechanical Equipment--->Load--->Find folder Metric/Imperial--->Mechanical--->Water side Components--->Pumps---Load any pump which is best representation of a pump component in your system....The final step is only to position that pump into the system and use its connections points to the prearranged pipes...BR
Nachricht 3 von 4
FacebookGroupMember
als Antwort auf: Rak.Marcelo
Autodesk Community thank you very much...team. I just couldn't find the right folder in the liabry which is my problem. I am using Metric measurements so yep...thanks, let me try it and I will inform you.
Nachricht 4 von 4
Rak.Marcelo
hope it helped
