Gap between Rooms
Gap between Rooms
info
Gap between Rooms
info
HI,
I have a room which I need to extend to the next wall,
I've switched on Room Lines & hidden walls, but I can't see any reason for the room boundary to stop,
same is in plan view. (See attached)
HVAC-Novice
Use a floorplan view and make room separations visible. Or some other room-bounding element is in the way? Many things can be invisible. Try 3D views etc. to find to you unknown items. Could be a linked model? Or share the model
Revit Version: R2026.4.2
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
