Hi all,
I want to give a gap of 15 mm between the curtain panel mullion. how can I create it? I created a family that included glass and the mullion with a gap but it acts as a single-family so I didn't get the exact schedule. could you please help me to find this
Solved by RDAOU. Go to Solution.
@mgb228 wrote:We work in actual architecture offices, every day. I, like the OP, have a good reason why I'd like the mullion to have a 1/2" gap at the rough opening. We seasoned architects and designers don't need a reminder that something (sealant, backer rod, etc) will ultimately be placed in that gap.
So if you don't have an answer to our question, consider not contributing at all. Or try this, "Sorry, there's no way to do that in Revit. We'll take note and add that to the next version." That would be better than gaslighting us in our own areas of expertise.
Maybe Autodesk can replace the condescending explainers with Chat GPT? That would probably eliminate the ocean on non-sequiturs in these threads- not to mention be a better data collection tool for the developers.
Wow! That was kind of harsh and uncalled for. Are you having a bad day? Need a hug? Here you go...
