Galvanized Steel Grating & Top Level going passed in constraints
Message 1 of 11
Hello:
So I have a few questions:
1) I am trying to make a slope from the T.O. Steel high to T.O. Steel Low Side, but I don't know how to make it connect? I have the needed slope, but I can't figure a way to connect the high slope point to the T.O. Steel high, and the low slope point (end point) to the T.O. Steel Low Side.
Capture.JPG2. I am trying to create a Serrated. Galvanized Steel 19-W-4 1-1/2" x 1/8" Steel grating, but I am not sure what that means? I've seen pictures of what it is, it is like a steel floor with spacing having small gaps like squares or rectangles, but I do not know what any of this means? I was wondering if anyone could model it for me? or give me direction how to approach the model?
3. I am trying to place rebar at the foundation where the concrete is, but I cant seem to get it right. Here is a picture of the model, but I can't seem to get the rebar correct when I go to structure, rebar, click OK, then I did Sketch Rebar and tried to sketch, but I couldn't get it. I was on the T.O. Concrete floor plan level, so I think I was in the correct one?
Replies (10)
Message 2 of 11
You might try searching on-line for a Revit family that you can download and inspect.  Use the keywords: Revit Family, Serrated, Galvanized Steel, Grate.  Betcha you find something.
Message 3 of 11
I searched already and couldn’t find anything. That’s why I’m posting here.
Message 4 of 11
No hits for grates???  You don't need to find one that models the serrated edges. That level of detail is silly.
Message 5 of 11
@Anonymous wrote:
Hello:
If the they are structural members then you can grip drag the column top to meet the beam.
I would advise against modeling it.  Adding those holes to your model with bring the performance to a crawl.  Create normal roofs/floors/ceilings for horizontal or sloped surfaces, and normal walls for vertical surfaces, then apply a material that resemble the grating (revit has some already, you juts need to load them in your material library.
Not my forte.
Message 6 of 11
joe_keogh
Hi @Anonymous
Try cutting a section though the Concrete foundation then place the Rebar.  Good luck
Joe Keogh
Director | Design Technology + Innovation
www.viewlistic.com.au
Message 7 of 11
I am still unsure how to get the roof to slope. Here It was I have. I measured the slope degrees to be 4.76 degrees, which I put, but I can't get the right side to be sloped. I am unsure how to make it all be one, instead of two roofs sloping towards each other.
Message 8 of 11
joe_keogh
Hi @Anonymous
This is what you have drawn, with two lines defining the slope:
You need to un-tick Defines Slope for the High end of the roof:
Joe Keogh
Message 9 of 11
I do have it unchecked. I don't know how to define the slope to make it go down from 136' - 5 1/2" to 133'-9".
Message 10 of 11
joe_keogh
To slope up, do it as I have pictured, to slope down Apply "Defines slope to the opposite end and set slope as negative value
Joe Keogh
Message 11 of 11
Hey @Anonymous!  I did find a serrated knife on-line.  That work?  I can clean the blood off of it and send it to you if you want.
...of course I'm fooling.  No blood on it.  😉
