Furniture showing different outlines
claudiakopietz
Message 1 of 11
claudiakopietz
hello there,
we have a project where the furniture, casework and plumbing elements from a linked model are showing with different outline colours on different floor plans. see image attached (one is white and another one is grey halftone as we need).
-this is only happening on the linked model
-we are linking the model per linked view
-the linked model is showing halftone on all floor plans but when linked if changes
- the families are the same
- view template is the same
-VV settings are the same for all elements.
any clue what can be happening?
Many thanks
Claudia
Replies (10)
Message 2 of 11
RDAOU
@claudiakopietz
  1. Check view Discipline
  2. Check Filters (Rule based view Filters and Phase filters)
  3. Go to visibility graphics and Check if link is set to Underlay / Halftone
Message 3 of 11
claudiakopietz
no they are not ticked.
I tried playing around with all the settings maximum I can do is to change for a really light colour that does not show properly in the plan.
I tried ticking the halftone just for the furniture in the custom settings in the view template does not work as well... tried to clear overrides and apply halftone does not work as well.
is just strange because is just 2 floor plans and all of them have the same view template with the same settings!
Message 4 of 11
Lachlan-JWP
Check that the elements you are having trouble with have their settings included in the view template.
Does the linked model use a view template for the plan views? It may have slight differences in colour overrides applied...
Message 5 of 11
syman2000
What is the phase filter set to? Also do you set your discipline as Architecture or Coordination?
Message 6 of 11
RDAOU
@claudiakopietz
That is one of the 3 mentioned possibilities in the previous reply!! Did you check the rest?
  1. Check Phase Filters (set to show complete and make sure that filter shows new/existing by Category)
  2. View Discipline?? In main model and link if the Display of the latter is set to By:Link
  3. View Filters?? under visibility graphics in the main model (also check filters applied in the link it is set to display by Link.
Alternatively, Attach or DM a link to the model to check it and suggest accordingly
Message 7 of 11
claudiakopietz
both are a NIA floor plan using the same template and same settings. and we set as Architectural for the discipline.
Message 8 of 11
claudiakopietz
this is an NIA plan using the same view template for both views! I have stated that in my description 😉
we ticked off the Revit link overrides in the view template as we need to link the views by the link view per floor.
Message 9 of 11
claudiakopietz
I have checked all this you are suggesting is the first thing I have done! The plans use the same settings because they use the same view template the only difference between them is because we are linking views by Link! but in the main model of the linked model all is fine is just when linking and applying the area color scheme that changes the line colors for the furniture.
Message 10 of 11
RDAOU
@claudiakopietz
Color scheme is set to background of foreground?!
If it is set to foreground it can cause that effect (lines appear like washed off halftone).
Message 11 of 11
curtisridenour
I think @RDAOU was on the right track with Underlay settings. Try seeing if changing the Underlay settings to uncheck Apply Halftone. See if that makes a difference in your view. If not, ignore what i said.
