Furniture graphic lines overlap partition lines when I make the furniture halftone. Therefore, when I create a pdf it looks so weird and not acceptable for client. Any solution for this?
I know furniture are non-cuttable category, but it does not make sense to have the furniture lines showing over the partition lines.
Is this something that has been dealt with on the new versions of Revit? I am using Revit 2022.
Thank you
How high do those walls go, are they below the furniture? Because that's not how it looks for me, and I don't think it's Revit 2022 vs. newer ones thing.
This is a pdf I created from the file attached. You can test by yourself.
Thank you!
When exporting check "Region masks coincident lines". That will solve furniture that is lower than cut line, for those that are cut, as in your example, I have no solution.
