When I open up Revit and try to hit enter on a commend the entire screen locks/freezes/ gets stuck and won't let me click or save or do anything with it. I imported a project made on revit 2018 and it upgraded to a revit 2020 model. I can look at the project but cant do anything with it
What command are you trying to active by hitting the Enter key?
Is it only a problem with the upgraded file?
Does it happen in Revit 2018?
try to tick audit first before opening the file and switch off use use hardware acceleration from options and see if helps .thanks
