Free Autodesk courses to help strengthen skills in Revit ✏️
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi Revit Community!
In this fundamentals course, you learn how to add shading and shadows and create a cloud rendering. This course is for anyone moving from 2D to BIM or is new to Revit.
https://customersuccess.autodesk.com/connected-learning/course?id=273
Importing a Civil 3D TOPO surface and site information into Revit allows you to see how the building will look in context with its surroundings. In this unit, you learn how to take advantage of work already done by the surveyor and/or civil engineer saving you time in recreating their work.
https://customersuccess.autodesk.com/connected-learning/course?id=283
The quality of your plans, elevations, and sections are more important than a business card when it comes to winning more work. Learn how to make your plan, elevation and section sheets communicate the professional image you want your firm to be known for.
https://customersuccess.autodesk.com/connected-learning/course?id=297
Setup the shared coordinates at the beginning of the project to reduce design errors and make collaboration easier across disciplines. In this unit, you learn what questions to ask in order to define the project coordinates. Then you add the shared coordinate to the Revit model to ensure everything lines up across disciplines and design firms.
https://customersuccess.autodesk.com/connected-learning/course?id=277
The course was recorded by Andrew Ward, Advanced Manufacturing Consultant here at Autodesk. Start Learning now! https://customersuccess.autodesk.com/course?id=298
Reviewing your projects' design and documentation is a critical task for ensuring project success. You must get feedback from other design team members, approving parties, and the client. Communicating that feedback so it is clear and understood is essential. In this module, learn how to add comments in the Revit model where it can be directly addressed. https://customersuccess.autodesk.com/connected-learning/course?id=337
Investigate solar angles. Site lines, easements and more. In this module you learn how to create mass objects in Revit to show where the building cannot be built to better understand where it can be built.
https://customersuccess.autodesk.com/connected-learning/course?id=278
Use BIM data to evaluate better alternatives for your design in real world context. Learn how to optimize the design and make informed decisions, based on information behind the design, before breaking ground in a fraction of the time.
https://customersuccess.autodesk.com/connected-learning/course?id=333
There is a trick to allowing everyone to work in one model without overwriting what someone else has done. Share one central Revit model with a wide team using work sharing.https://customersuccess.autodesk.com/connected-learning/course?id=334
There is a trick to allowing everyone to work in one model without overwriting what someone else has done. Share one central Revit model with a wide team using work sharing. https://customersuccess.autodesk.com/connected-learning/course?id=394
BIM 360 Design is an efficient way to share your design with the entire team. In this unit, you learn how to upload your model to BIM 360 to monitor changes to elements in a multi-discipline project in the cloud and identify potential issues.
https://customersuccess.autodesk.com/connected-learning/course?id=280
Generate toolpaths https://customersuccess.autodesk.com/connected-learning/course?id=299
The focus of this course is to learn what it takes to take flat 2D AutoCAD drawings and turn them into 3D Revit projects. Using existing information to create new projects helps save time and money. https://customersuccess.autodesk.com/connected-learning/course?id=404
Welcome to Creating Lighting Plans using Revit. Lighting Plans are needed for permit drawings. They show the lights with tags, connections to switches, and schedules and legends that provide information about the lighting fixtures. https://customersuccess.autodesk.com/course?id=498
All the best,
Daniel
