pdf printing problem
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
umbachdw
709 Aufrufe, 5 Antworten
I am having a printing issue.  There is a color elevation view on a drawing sheet and whenever I print it to PDF or DWF it just comes out black.  I have tried it with different pdf printers, tried dwf, tried different printing qualities, no luck.  That window will not print.  When I print only a portion of the sheet I can get it to work, but not the full sheet.  looks like this_001.png
Should look like this.
Any ideas?
I have 32GB ram, quadro rtx 4000 video card and i9-9000 processor - if that matters.
Tags (1)
5 ANTWORTEN 5
Nachricht 2 von 6
syman2000
als Antwort auf: umbachdw
Did you try raster print instead of vector and still get the same result?
Nachricht 3 von 6
umbachdw
als Antwort auf: syman2000
Its set to raster already.  There are some other "realistic" 3d views on the sheet.  Those print fine - its just that color elevation that won't print.
Nachricht 4 von 6
syman2000
Check this link and see if that resolved your issue.
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Nachricht 5 von 6
_Vijay
DWG also the same issue you are facing?
Nachricht 6 von 6
umbachdw
Looks like Revit does not like printing multiple color views on one sheet with different antialiasing settings.  The sheet prints fine when antialiasing is set the same for all of the color views.
