formula text
formula text
kboschJGDNZ
Message 1 of 9
formula text
kboschJGDNZ
Hey
Is it possible to use a text parameter in a formula. I want a yes/no parameter to check whether a condition is met in another text parameter.
If(text=banana, yes,no)
Is this possible??. I'm only getting errors.
Replies (8)
Message 2 of 9
kboschJGDNZ
I'm always struggling with text parameters. Is there also a way to combine the content of two text parameters? something like : text1 & text 2
Message 3 of 9
You cannot use text to drive a formula. Use a yes/no, number, or integer instead. Go to the Revit Formula link in my signature below to entertain yourself.
Message 4 of 9
You don't need a formula to combine 2 text fields. If in family, use a label and add two fields in it, if in project schedule, use a combined parameter.
Message 5 of 9
kboschJGDNZ
I want to make a label that will check the strengthclasses of columns. A strengthclass is a combination of text and numbers like S275. If a column has the standard strenghclass it should hide that strengthclass. I can't figure out a way to get this working.
Message 6 of 9
- Presume you already have the Strengthclass parameter (text)
- Create a Strengthclass_standard yes/No parameter.  (yes = standard met)
- Create a Strengthclass_report parameter (text). Use formula: if (Strengthclass_standard, " ", Strengthclass)
Message 7 of 9
kboschJGDNZ
Thanks for your reply... I've created a label with your setup, but still don't understand how it would work.
The following screenshot is from the label family:
When these are the occuring strengthclasses (S235 / S275 / S355)...how can you  hide the S235
I've tried to fill in a formula in the Strenghtclass standard row: not(StrengthClass="S235")
That however doesn't work
The "StrengthClass" parameter is a shared text parameter btw.
Message 8 of 9
kboschJGDNZ
if(StrengthClass="235",1=0,1=1) gives me a warning about the improper use of booleans
Message 9 of 9
I will get back to you on this tomorrow.
