formula for text parameters?
kadmonkee
Advisor Advisor
Message 1 of 8
kadmonkee
I have (3) shared Parameters that each have the same value
1. Room Number
2. Apartment Number
3. Unit Number
all are text parameters that report the alpha numeric value (ie:) R-340
is there a formula that would allow me to enter the value once (room number) and have it populate the other parameter fields?
I keep getting syntax and other errors.
thank you for any help with this.
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
Replies (7)
Message 2 of 8
like this?
Message 3 of 8
kadmonkee
thanks for the reply, that option is not available for my room schedule.
I did mistakenly leave that piece of information out of my question.
I was thinking of a formula in a schedule for calculated values using text parameters.
I cant seem to get the syntax correct
thank you
Message 4 of 8
BDMackey
If these value truly are the same then you can do this without Shared Parameters.  In the room tag add a label that is a formula to equal the Room Name (do this twice).  In the schedule add a formula to equal the Room Name (again do this twice).
If you are trying to use the shared parameters I don't think there is a way to do this.  I have attached a simple Dynamo script to copy one parameter value into another.  If using Dynamo Player then you can choose the values being copied.  Downside is obviously this has to be ran anytime there is a change.
Message 5 of 8
kadmonkee
thanks for the idea
these are shared parameters to be used and filtered in a variety of schedules.
the formula needs to be added into the conditional formatting tab of the schedule itself.
it seems I have painted myself into a corner here.
manually enter then copy paste throughout
thank you
Message 6 of 8
BDMackey
I assumed it was a bit more complicated than it seemed.  That is why I added the Dynamo Script because I have several clients who do some similar things and the copy paste is way to tedious to watch let alone do. 🙄
Message 7 of 8
Do you need them for a schedule or tags?  Below is an example if schedule.
Message 8 of 8
kadmonkee
I need them more for scheduling as the room tag covers the room number.
I currently do not have 2019 Revit installed.
I will try to get that soon.
thank you
thank you
