Formula-driven Family Type parameter.
Message 1 of 19
In my Family I have a parameter of type <Family Type>. I want it to be controlled by a formula. I have problems with defining this formula. For the simplest example i just copy the whole name of family and the type and paste to the formula field. I receive an error (see picture below). What is the correct way of typing type names into the formula field?
Replies (18)
Message 2 of 19
Sahay_R
The highlighted item in the screenshot is what really needs to be in the formula. Watch out for cases and typos!
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 3 of 19
Thank you for your reply, but could you please be more specific about the syntax? I was trying different Options (for example Abtropfbrett Typ<IPN_Abtropfbrett : 300 mm> but nothing works.
Message 4 of 19
Sahay_R
Parameters are all in the extreme left column. From your screenshot, it appears that the formula includes information from the middle column. If I am incorrect, then a clearer screenshot with the error message moved away from the dialog box would be appreciated.
Here's how parameters are organized in the dialog box-
1) Left column = Parameter
2) Middle column = Parameter Value
3) Right column = formula, if any
The Formula is made out of Parameters, which will come from the left column.
Rina Sahay
Message 5 of 19
You're right. In the formula field I tried the simplest possible way of assigning Parameter value using a formula. If the Parameter type would be let's say Integer, then if in formula field I would type "500", the Parameter Value would be set to 500. Apparently Family Type Parameters require different Syntax of formulas which is unknown to me.
Message 6 of 19
Sahay_R
What exactly is it that you want your formula to do?
Rina Sahay
Message 7 of 19
I want the parameter value equal IPN_Abtropfbrett : 300 mm if the value of Lenght is over 300 and  IPN_Abtropfbrett : 600 mm otherwise.
Normally it would be something like if(Lenght>300,"IPN_Abtropfbrett : 300 mm","IPN_Abtropfbrett : 600 mm")
Message 8 of 19
Alfredo_Medina
Family Type parameters cannot be set to a formula in a simple way. You need more parameters, one Family Type parameter for each variation, and one integer parameter to define which variation.
There is an example of this technique in "Exercise # 6" of this article that I posted in Linkedin:
https://www.linkedin.com/pulse/repetitions-randomness-revit-part-2-alfredo-medina/
Message 9 of 19
Alfredo_Medina
Hello,  @Anonymous
Just curious, what was the end of this case?
Message 10 of 19
Grigor_Panosyan
The way you suggested in exercise 6 doesn't seem to work, I have tried to recreate the Hexagon family exactly as it is displayed in the Type Properties, but all I get is "The following parameter is not valid" after inserting the formula. I want to find out the right way of connecting Integer and Family Type parameters via a formula, but, unfortunately, I have no luck doing it.
Message 11 of 19
Peter.Banski
Observer
Observer
Thank You Alfredo,
Your Link is the one and only solution in the whole WWW that I found, how to steer "Family Type Parameter" with a Formula.
And it works very well!
Peter
Message 12 of 19
Alfredo_Medina
@Grigor_Panosyan wrote:
"The way you suggested in exercise 6 doesn't seem to work, ..."
_________________________________________________
Please try again. It does work.
Message 13 of 19
Grigor_Panosyan
Dear @Alfredo_Medina,  it does work like a charm, indeed I was doing something wrong back when I posted my reply.
Integer x Double Family Type x "if" statement became one of my favorite technics
Message 14 of 19
Roberto.CabanasEPSPH
Observer
Observer
Great!!! Brilliant explanation and technique.
Message 15 of 19
jquarry
Is this still the best (and only) way to drive Family Type Parameters in formulas?
Now that it is 2022 I figured I might save someone some time doing any additional searching...
Message 16 of 19
Alfredo_Medina
Hello, @Peter.Banski and all of you participating in this thread. I want to add that I have made a video about this topic, how to control family types by formula, plus another topic, how to apply random values to those family types. If you're interested, please follow this link:
https://www.youtube.com/watch?v=_8Md-Vrw8PU
Message 17 of 19
adriansin_randalllamb
Adding to @Alfredo_Medina  's solution. The formulas also work with Yes/No checkboxes. Yes/No checkboxes can be more intuitive for users. Thank you so much for the solution.
Message 18 of 19
Rafael_Lucki1
don't use this type family parameter, use visibility parameter to turn of other familys nested on you main because it does work better to write formulas
Message 19 of 19
naylin.oo
Thanks a lot, it very helpful for me.
