Help with adding drywall to studs
emilysJF4NU
Observer Observer
emilysJF4NU
Observer
Observer
Hello, I am doing BIM modeling for a building and we have placed our studs and track in the model but the modelers want us to pull the drywall from the master file and place it into our NWC. Can anyone help with this? I know you can place drywall on every wall, but he made it sound like I should be able to transport it from their model to mine. Thanks!
Ryan_GormanKT36T
Probably need some more info to help you get there.
You should be able to export the walls with the drywall. Not sure what your workflow is.
  • How are you creating the NWC?
  • DO you have access to the Revit model that has the drywall modeled?
Here are a couple pages that may help:
Navisworks Help | Revit File Exporter | Autodesk
Help | Publish to NWC | Autodesk
