Force Revit DB Link to Truncate data and not ignore it.
tony.harwood
Message 1 of 1
tony.harwood
Hi, We've recently discovered that Autodesk Point layout creates a hidden parameter in Project Information called "GTPS_Storage_Param" after running it. That parameter has data in it that's 10,420 characters long. When we try to export the model data with the Revit DB Link add-in, we get the error code: -2146232009. The error goes on to say "String or binary data would be truncated" and then "The statement has been terminated". We would be fine if that GTPS parameter's data was truncated, but it doesn't just do that. It doesn't write any of the project info data in the export. We looked in the settings of the Revit DB Link add-in for a setting that would truncate the data to 256 characters but didn't see anything. Is there a way that we can force the add-in to do so? Is there another approach or tool we should be using? I've attached a couple screenshots for you all to see. Thanks in advance! TonyH
Replies (0)
