In Closed Workset for linked models
8 ANTWORTEN 8
GELÖST
Nachricht 1 von 9
Jason_S
17558 Aufrufe, 8 Antworten
I have a model that all the linked models show under Manage Links as "In Closed Workset"  The models now are not showing in any views.  I can't seem to find the correct combination to get them to turn back on.
What am I missing?  Has to be something easy I am hoping.
Thank you.
8 ANTWORTEN 8
Nachricht 2 von 9
als Antwort auf: Jason_S
It is in a workset that is closed. Create a view and open all worksets to see if it shows.
Nachricht 3 von 9
Jason_S
als Antwort auf: ToanDN
WOW.  That was way too easy.
Thank you very much.  Sometimes I dig to much into it and it isn't that deep.
Nachricht 4 von 9
PaulineP54QC
Hi ToanDN,
I am having the same issue. What does "In a workset that is closed" mean? and why is it happening? When you said "create a view" what exactly did you mean? I created a "Plan view" and it did not work. Please any help would be appreciated. Thanks!
Nachricht 5 von 9
als Antwort auf: PaulineP54QC
It means the link is kept in a workset that is closed, exactly what it says.  Open the workset manager window and open any closed worksets then you will find it.
Nachricht 6 von 9
PaulineP54QC
Thanks ToanDN! I am not sure why It happened but I would like to know so it will not happened again.
Nachricht 7 von 9
There are several ways it can happen:
- Open a project and specify to open/close certain worksets.
- Someone closed certain worksets, sync the project.  You open the project and inherit the open/close status from the Central.
- Go to Worksets dialog in the project and close certain worksets
Nachricht 8 von 9
PaulineP54QC
Hi ToanDN, sorry for replay so late. Thank you so much for your response!
Nachricht 9 von 9
mrodgers_3GHP4GM9K5DB
So what would you do for a model that is attached to a model you are linking in?
Arch Model (levels workset A) > Coordination Model (levels workset B) > Sub Model (workset B closes, workset A shows)
