Fly button disabled in navigation bar
dyp4f
dyp4f
Hi all.
I cannot enable the “fly mode” in 3d view.
In navigation bar, the “fly” button is grayed out (disabled)
Does anybody know how to fix it ?
(I have Revit 2020.2.0.48)
borakin1
Hi i think you are on plan or elevation (2d screen). Using Walk or Fly Mode Walk and Fly modes can only be used in a perspective projection (a camera view).
Bora AKIN
Mimar
Twitter | LinkedIn
Verilen cevap sizin için çözüm mü? Eğer çözüm ise  ÇÖZÜMÜ KABUL ET  veya BEĞEN Kudos.jpg butonu ile ödüllendire bilirsiniz.
zxron
Hi, Kon Asim!
Fly mode works in perspective view mode. Click with rmb on view cube and select Perspective. After that you can use fly mode. Just clik on button wich looks like a paper airplane on right panel.
dyp4f
Yes, you are correct Bora Akin. I was in 3d Orthographic view and not in Perspective.
Thanks.
dyp4f
Thank you for your help. It works.
