Hello
I have problems with starting up my trail version of RevitLT 2020.
I know it has to do with the checking of the license somehow (still have 13 days left of trail by the way)
When starting the program I get the error in the script file (see attached PDF)
If I click on "ja" (yes) I am getting the image with the translate error (see attached PDF) and can't use the program
Any ideas or solutions?
Thanks in advance!
Nico
Have you tried to reinstall it and to use the rest trial with the same licence?
can you tell me which language you are using? I want to read it out in English
Or could you translate that line in English where you clicked on "ja"
I figured it out what was that line. It is something related to addin error. You need to uninstall or remove latest add-in
Or else try this:
Go to C:\Program Files\Autodesk\Revit 2018\AddIns
Revit 2018 or whichever version you use.
Cut Paste the AddIns folders so that you wont lose those addin
Restart your PC and open the revit file again.
