Hi, im using Flow Design (Standalone) / STL export because its not available on revit 2018
The Visibility Toolbar above the Ribbon (normaly located at the left corner) is not visible.
I try to change my screen display / resolution / etc but it doesnt change anything on the software.
Im using windows 10 pro with a Quadro M1000M. (see attachments)
Regards
I've seen this happen (and get corrected) with other add-ins. When 2017 was first introduced, there was a similar thing happening because of a conflict with Dynamo.
Submit to Autodesk.
This is a Revit Forum.
hi, i was finaly able to clic (by chance) on the toolbar (the flowdesign forum seem to be close I got redirect to revit forum, anyway it's for revit use).
It's still hide in the corner, but im able to guess and clic just below to get the command. It's clearly a graphic display problem.
I still think flowdesing should be reintroduce inside revit 2018. Right now i have to export my model to STL format to use it.
See image
