Flow configuration options for connector
Hello
I am not getting what is flow configuration for a connector,  while creating a family in Revit which is related to plumbing or hvac.
and what is that 3 options like preset, calculated and system, which one when we have to use???????
 kindly Can anyone explain me......
dzanta
The Flow Configuration for a Connector allows for the "flow" of data thru the family to the additional components that make up the system.  Depending on what system you are building, what family type your building (i.e. VAV Box, Air Diffuser, etc.), the Flow Configuration can be set to your desired engineering needs.
Here is a link to an old AU class (2008) that helps...
http://thebuildingcoder.typepad.com/files/me204-3_connectors_in_revit_mep_content.pdf
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
Alfredo_Medina
There is a handout from Autodesk University that explains these concepts. This document can be found searching by "flow configurations" in the Help search in Revit:
