Floors Hidden lines
Floors Hidden lines
mairh_tsek
Message 1 of 19
Floors Hidden lines
mairh_tsek
Hello all,
I have a floor in Revit with multiple slopes. I dont want to see the slope lines so in the VG I turned them off, but when I print in PDF I see their possition.
Do you have any idea how I would not see them ?
Thank you!
Replies (18)
Message 2 of 19
Sean_Page
Do they still show if you tab through and Hide in View?
Sean Page, AIA, NCARB, LEED AP
Senionr Partner, Computational Designer, Architect
Message 3 of 19
mairh_tsek
Thank you for your answer,
When I press TAB, I can select the floor
Message 4 of 19
Use the Linework (LW) Tool on the Modify Tab.
Message 5 of 19
mairh_tsek
I have many slopes and 4 floors with large long, so the LT it will take me a lot of time.. what I did it was to keep the hidden lines on, and to gave them the same color as the surface of the floor. The result is better but I can still see them in the pdf
Message 6 of 19
 Are you saying that the PDF shows that linework even if you override the Floor's Projection Line Color to be the same color as the Material's Graphic Color?
What is the View's Visual Style?
Message 7 of 19
mairh_tsek
I override the color of the projection lines to be the same as the color of the surface (Image 1). and the result in pdf is in the image 2. In Revit, if I don't select the floor I don't see the lines.
Thank you for your time!
Message 8 of 19
What's the View's Visual Style? Are you processing the PDF as a Vector or a Raster?
 ...try using the "Replace halftone with thin lines" option in the Print Setup dialog.
Message 9 of 19
No issue here using Export to PDF in Revit 2022.
With Interior Edges visible:
With Interior Edges Invisible:
Message 10 of 19
mairh_tsek
Actually in your pdf you have the same problem as me...you see the white lines where you had the slope
Message 11 of 19
mairh_tsek
Visual Style : Hidden Lines, Vector Processing, Printer : PDF-XChange Standard
"Replace halftone with thin lines" : Nothing happens
Message 12 of 19
You know, I'm not able to replicate. Have you tried another PDF printer?
Message 13 of 19
I don't know what pdf viewer you are using but I don't see those line in my AdobePDF.
Message 14 of 19
Lachlan-JWP
I get very faint lines in Adobe Acrobat Reader DC, but it's far more noticeable when viewed in my web browser (see below)
@mairh_tsekwhat pdf viewer are you using?
Message 15 of 19
mairh_tsek
In both Adobe Acrobat Reader DC and PDF-XChange Editor I have the same result
Message 16 of 19
Lachlan-JWP
It appears that I can't replicate this issue either.
Here's my own attempt. The interior lines disappear as expected.
I've also attached my project file & a print pdf for comparision.
Message 17 of 19
Lachlan-JWP
Oooh, I can see the lines when I preview my uploaded pdf but not when I download it. Can you download my pdf and see if the issue is still there for you. This is starting to look like a graphics issue.
Message 18 of 19
mairh_tsek
Thank you for the test. When I download your pdf and open in with Adobe Acrobat Reader DC, I dont see the lines. But when I open it with PDF-Xchange Edit I see them.
In my case when I open my pdf with both pdfs readers dont work
Message 19 of 19
Export to Raster PDF:  no lines
Export to Vector PDF:  only see the lines if I zoom in very close in Adobe Acrobat pro 2020
@ 6400% zoom level of a 8.5x11 PDF
@ 100% zoom level of the same PDF
