floor visibility
floor visibility
stevensonJQWEF
floor visibility
stevensonJQWEF
Dear all,
The main model has been created structurally.   I have now tried to create the architectural floor on top this floor.  (shown in picture is the sketch drawn, and then after finished sketching the model).
As you can see, the architectural foor is not visible.
The discipline has been selected correctly to architectural, and also in visibility graphics all floors seem to be visible.
Does someone have another suggestion why i cant see this additional architectural floor in the model?
Thanks in advance!
ralphdenhaan
Does your 3D architectural view contain filters? Maybe you are filtering Structural Floors?
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
LinkedIn | LazyBIM Blog
stevensonJQWEF
hi, how do i check these filters?
kostask_oionei
Do you get any message when you finish edit mode?
Check also the phases and the filter visibility.
If you work with worksets check also the workset visibility.
If my post help you, please give a like.
If your question was answered please mark it with ACCEPT SOLUTION. This helps others to find answers...
Kostas Kouris
Architect Engineer, M.Sc., ACI, ACP
kostask_oionei
Visibility Graphics -> Filter
Visibility Graphics -> Workset (If you work with worksets)
Kostas Kouris
ralphdenhaan
Check the Visibility/Graphic overrides Filter tab:
stevensonJQWEF
amazing, that works thanks!
