- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have had an issue with cross selecting things in the plan. Floor slab is always in the way, whenever I try to cross select something, the floor slab will be the one selected and dragged; so I pin the floor slab, still can't solve the issue. So, I end up having to keep hiding slab whenever I need to select and edit something. Not sure what cause this and how to fix it? Thank you!
