- Mute
- Permalink
- Report
Good day, everyone. I hope you all will take pity on a poor structural engineer. I'm new to Revit and could use some assistance. This particular question seemed more architectural than structural, so I'm over here in the Arch forum.
I'm running Revit LT 2021 ($100 to add it on to AutoCAD LT seemed an inexpensive opportunity to learn my way around the program), so I know I'm going into some things with one hand tied behind my back.
I'm trying to model a light frame wood building, and looking at the point where the attic floor, roof, wall, and soffit all come together. Is there a way to shave off the portion of the floor that extends above the roof line, cut a birds mouth in the joist, and/or trim the tail of the rafters to be even with the bottom of the soffit? I've tried using the Join command, but it will only keep the outer edges of all of the elements (so almost exactly the opposite of what I want). The Cut geometry does nothing - I might be using it wrong, but all the tutorials seem to point to using with families and voids.
I appreciate any help anyone can offer.
