In Revit 2020 I could select raytracing visual style. That option has disappeared completely after I updated to Revit 2021.
Gelöst! Gehe zur Lösung
Gelöst von loboarch. Gehe zur Lösung
Raytrace was removed and "real time" lighting effects have been integrated with the "realistic" visual style. It looks better than the ray trace mode did (subjective opinion) and is far faster than ray trace (objective fact.)
http://help.autodesk.com/view/RVT/2021/ENU/?guid=GUID-F8F2FB5E-C4BE-495C-A1B1-DB425A0926A8
@Anonymous wrote:
where is the solution ?? , this is not helpful
Raytrace does not exist as a visual style in 2021 and beyond. It was replaced by newer technology to achieve a faster in canvas result. I would argue the appearance is better than the old raytrace visual style. If working in a raytrace visual style is important to you, you will need to remain on Revit 2020. I do think the current implementation is just as effective if not a better experience.
I want raytracing back too. The new visual style could have just been added.
