Floor plan "Shadow on" is greyed out, please help!
Message 1 of 13
Only one of my floor plans shadow on is grey, I checked all the settings seems fine.
Please help!
Replies (12)
Message 2 of 13
mauricio_mssf
You have checked shadows in the view configuration (or view configuration of the viewtemplate)
type VG and deselect the shadow option, or disable in viewtemplalte as in the image below.
If the answer solves your problem, click Accept as Solution this helps other users to quickly find an answer and let a like if you liked it.
Você achou esta postagem útil? Sinta-se à vontade para curtir esta postagem.
Ficou satisfeito com a resposta à sua pergunta? Nesse caso, clique no botão ACEITAR SOLUÇÃO.
 Mauricio Santos Filho Arquiteto | BIM Manager
Message 3 of 13
Do you have a Template assigned to the View?
Message 4 of 13
Hi, how do I know I assigned to a template? Thanks
Message 5 of 13
Thank you for your quick reply. I didn't choose any template.
Message 6 of 13
It just worked!!!
Thank you so much!
Message 7 of 13
Look under "Identity Data" Group in the View Properties. Does "View Template" read something other than "None"?
Message 8 of 13
@Anonymous: What was it?
Message 9 of 13
If the Shadow is not ticked, how the shadow would show on the screen. I am just wondering.
Message 10 of 13
It was "none", I set up everything exactly like other levels but only this one didn't have shadow. I reset again and then all fine now : )
Thank you for your help!!!
Message 11 of 13
I'm confused.  So "Shadows" was greyed out before and now it isn't? And it had nothing to do with a View Template?
So, what was it then?
Message 12 of 13
drugs?
kidding.
Message 13 of 13
chimso
I ran into the same problem, and what it was on my view was that in the display properties, it was set at a transparancy... when I changed the transparency back to zero, the box became available. It might have been a coincidence, but that is my two cents.
