- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Going to try and make this simple. Under "Floor Plans" in project browser, I have a level or plan called "floor plan". Under "ceiling plans", I have a drawing noted as "reflected ceiling plan". I noticed on my building sections and elevations that the level at the floor plan is noted as "reflected ceiling plan". When I'm in my floor plan drawing, and click on a wall, the base constraint shows reflected ceiling plan. When I click on RCP, there is a drop down that I would normally change wall base constraint to floor plan, but there is no "floor plan" to choose from. When I go and try and add a new level to my section or elevation, and name it floor plan, it tells me that name is already being used and to use another name. So how did my floor plan get on the RCP, and where did the floor plan level go? All my exterior elevations and building sections shows the floor level as RCP
