Floor pattern showing on top of walls (printing problem)
Hello, I'm new to this forum so apologise if this is not the right place.
How can I make the floor pattern (it's a colour scheme) print correctly, and not on top of the walls. like the picture attached?
Edit: It also shows on top of furniture
angelica.rodriguez.3d
Hi
Check the location of the color scheme, it may need changing to background, so all the other elements are on top (furniture, walls)Capture1.JPG
Hi, thanks for your answer.
It's already like this.
It shows up ok in Revit, but like the previous image when I PDF Print it.
It is in the properties of the view. See image attched in my original post.
