Revit has started to crash without warning, and with no option to save recovery file.
Why is this happening? I used to get the message to save recovery file but no longer do.
I am having to manually save the file after most modelling operations, as a lot can be done in 15min !!
This is becoming frustrating, and i have started another project in another piece of software cause i'm getting annoyed with this.
Is there a solution? or do I have to continue with this.
Attached journal file for anyone that knows what to look for.
@sdalrymple hello, have you try to install latest updates and service packs from autodesk and see if helps. thanks
Hi, thanks for your quick reply.
I have my Autodesk app manager running in my task bar and it tells me there are no updates.
I am on Service pack 2, the code is 20150701_1515, however I noticed a new build number in another service pack. 20150714_1515.
Should my Autodesk app not recognise the change and update?
I'll download manually, and try this update.
