Floor following topography using Dynamo
r_thinagar
r_thinagar
Can anyone please help me to solve this issue . When I used dynamo to floor following topography, some cases it works but in some cases it resulting this issue (Slab Shape Edit Failed).Please find the attached image.Thanks
Mark.Ackerley
Hey,
I'm not sure which package your rooforfloor.bypoints node is from, but there's a similar one in Clockwork "Floor.SlabShapeByPoints" which I have used successfully on very complex shapes...
In your case, I suspect that if you "PruneDuplicates" that might help, perhaps get rid of points closer than 50mm?
Incidently, incase you weren't aware, Dynamo has a dedicated forum at https://forum.dynamobim.com/ where you might get more responses.
Hope that helps,
Mark
