Flipping a wall
Flipping a wall
jfjacques
Flipping a wall
jfjacques
If I select a wall and want to flip it using the flip( little blue) arrows. This seems to push the wall to some random location.
As far as I know the only workaround is the mirror command. But it destroys the existing dimensions and tends to break the existing joins.
Avaris.
Try this:
-Select the wall
-Set alignment on wall center (top bar)
-Hit the spacebar
A wall is flipped along its Location line. If the location line is not Wall Center then the wall will shift.
cbcarch
https://knowledge.autodesk.com/support/revit-lt/learn-explore/caas/CloudHelp/cloudhelp/2017/ENU/Revi...
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Some Random Location???  It's not flipping about its Location Line?
