FLIP WALL ON CENTRE AXIS
6 REPLIES 6
wisedrawing
438 Views, 6 Replies
Okay for another quick one
when you realise a stack of walls are flipped the wrong way and the quick way is to hit space or the flip arrows, but that moves the wall and takes everything attached with it then you have to move it back to position
can a wall be quickly flipped on its axis and then you can move on, and keep the constraints and not have to move it back to position
mirror command spins the system out with delete warnings? that takes off all the constraints set up with floors and roof so that's not an option
6 REPLIES 6
anze.kumar
in reply to: wisedrawing
Do you have a compsite wall or a "single  material" Wall. If that is the case, you check with "Location Line" do you have chosen. To flip it on Centre Axis ou should have "Wall Centerline" or "Core Ceneterline"
If you have a compiste wall that is more tricky. Maybe try Aligning! the wall to a new position first, and then flip it. Aligning usually keeps the contraints, while Moving usuallly breaks it.
in addition that @anze.kumar says, if you have placed the wall with Location Line "finish face exterior" for example, change the Location Line to "Wall Centerline", flip the wall and then change it back to "finish face exterior".
If my post help you, please give a like.
If your question was answered please mark it with ACCEPT SOLUTION. This helps others to find answers...
Kostas Kouris
Architect Engineer, M.Sc., ACI, ACP
Are you talking about Stacked Walls? Flipping the upper/lower independently? If so, right-click and press Break up and Disallow Join.
https://www.youtube.com/watch?v=0n2tH36fyH0
Bingo thanks heaps, that's exactly what I needed
wisedrawing
in reply to: barthbradley
that's already answered another question for later that I don't need to ask
cheers
wisedrawing
in reply to: anze.kumar
perfect thanks
Forma Design Contest
