Flat top rail @ top step
12 REPLIES 12
Message 1 of 13
info
495 Views, 12 Replies
info
HI,
The top rail is flat @ top of stair case (for top step), I would like the rail continue straight up not flatten out.
When I create a new stair case the problem persists. Please see attached.
But when I open a new project the rail is parallel to the stair case which is what I want.
HI,
12 REPLIES 12
Message 2 of 13
in reply to: info
Edit Top rail type and set Top extension to the length you want.
Message 3 of 13
info
in reply to: ToanDN
info
Adding an extension doesn't change the flat section(at top) within the staircase.
The problem is the flat portion within the staircase instead of it continuing up parallel with bottom of staircase
Message 4 of 13
info
in reply to: info
info
Message 5 of 13
info
in reply to: info
info
this is when I create a stair case in another project. it works
Message 6 of 13
in reply to: info
Tick End with Riser for your Run.
When you place the railing, choose On Stringer instead of On Treads.
Message 7 of 13
info
in reply to: ToanDN
info
I'm sorry I don't understand.
Message 8 of 13
info
in reply to: info
info
your version of Revit looks different than mine
Message 9 of 13
in reply to: info
It is the same for any version.  Share your file here.
Message 10 of 13
info
in reply to: ToanDN
info
I'm sorry I can't.
I'm sorry I can't.
Message 11 of 13
info
in reply to: info
info
This is my properties for stairs
Message 12 of 13
RDAOU
in reply to: info
RDAOU
@info
One click you select the Stair
You need to  TAB and select the RUN then check End with riser
@info
Message 13 of 13
info
in reply to: info
info
Thanks that worked.
Thanks that worked.
