Flat roof, variable layer not working
13lemartinez
Message 1 of 8
13lemartinez
This is a really odd shaped flat roof.  The main structure is going to be TJI joists and I am using 2x6 on top to create the 1/4":12" slope.  I want the program to cut that layer to keep the slope on top and the bottom flat.
Replies (7)
Message 2 of 8
RDAOU
@13lemartinez
Are you using a floor element? it  works fine here....if you are, the next questions would be
  1. How odd are the sub-elements?
  2. Are you sure you are assigning the proper layer as variable?
Message 3 of 8
syman2000
Have you check on this variable
All you need to do is add a point and you should be able to achieve your slope and the bottom will be flat
Message 4 of 8
13lemartinez
These are the settings on my roof assebly.
Message 5 of 8
syman2000
You may want allow for more thickness for the TJI. If you have slope more than 5.5" depth, your roof won't accept those value. I would look at 5.5" + (slope variable).
Message 6 of 8
Is this a flat roof with modified subelements or a roof with slope definitions?  If you want the bottom to be flat, it must be the former.
Message 7 of 8
13lemartinez
it is a flat roof with defined roof slope.
Message 8 of 8
So it is not a flat roof.  A flat roof means no defined slopes, no slope arrows whatsoever.  Remove the defined slopes and modified sub-elements then it will work.
