Adding elevation views to different drawings/views?
16 ANTWORTEN 16
GELÖST
Nachricht 1 von 17
cjacobsLDX59
1020 Aufrufe, 16 Antworten
Hi all,
So I have a project with two structural plans in it. In one plan, I can add elevation views just fine, and yet in the other Revit won't let me (see below screenshot, NOTING THAT I'VE BEEN LOOKING INTO WAYS TO FIX THIS WITH VISIBILITY PARAMETERS, UNSUCCESSFULLY, FOR CLOSE TO 24H AT THIS POINT). Does anyone know what specifically might be preventing me preventing me from adding elevation views to this other structural plan?
Thanks in advance,
16 ANTWORTEN 16
Nachricht 2 von 17
RSomppi
als Antwort auf: cjacobsLDX59
I think the list in the message is somewhat specific. Without the model, it's hard to get any more definitive.
Share the model.
Nachricht 3 von 17
syman2000
Check and see if the elevation category is turn on.
If it is, check and see if the elevation is also set to large scale.
Nachricht 4 von 17
cjacobsLDX59
als Antwort auf: RSomppi
It's a model I'm working in for my job, so unfortunately I can't share it.
Nachricht 5 von 17
cjacobsLDX59
als Antwort auf: syman2000
Already confirmed each of these multiple times, unfortunately.
Nachricht 6 von 17
RSomppi
You've got the information that you need. You have a working view. What are the differences?
Alternatively, just create a new view using a view template created from the working view.
Nachricht 7 von 17
syman2000
Check and see elevation set to what discipline and hidden set to none.
Nachricht 8 von 17
cjacobsLDX59
Tried just now - no luck.
Nachricht 9 von 17
cjacobsLDX59
The differences is what I'm having a hard time determining, as they seem to have identical settings across the board.
I can't just make a new view, as I'd lose the days' worth of work I've put into my problem view.
Nachricht 10 von 17
Did you ask the same exact question in at least one other thread?  Set the elevation views' Discipline to Coordination.
Nachricht 11 von 17
RSomppi
You won't lose anything if you don't delete the problem view. Annotations can be copy/pasted.
Nachricht 12 von 17
cjacobsLDX59
als Antwort auf: ToanDN
I've been asking very similar, related questions because this problem has had me stuck at work for an entire day at this point.
I've already tried changing its discipline with no luck.
Nachricht 13 von 17
Please show the properties of the elevation view and the structural plan view in two separate pictures.
Nachricht 14 von 17
cjacobsLDX59
Structure:
Elevation:
Nachricht 15 von 17
Edit: @syman2000 is correct.  Your elevation only shows in full scaled (12" = 1') plan view.  You need to change the [Hide at scale coarser than] value to something smaller than the scale of your plan views (1/8"=1' as you show it).
Thanks but I need to see the full properties panel of the views, not the views drawing area.
Nachricht 16 von 17
syman2000
Your scale is set to 12" = 1'-0". Change it to 1" = 400'-0"
Nachricht 17 von 17
RSomppi
That would be coarser.
