fix levels attributed
7 REPLIES 7
Message 1 of 8
mohiroal
257 Views, 7 Replies
mohiroal
I am trying to make building upper than toposurface and topo be base level zero
@ToanDN @barthbradley
7 REPLIES 7
Message 2 of 8
in reply to: mohiroal
Go to Elevation and move the Toposurface down.
Message 3 of 8
mohiroal
in reply to: barthbradley
mohiroal
if possible make Toposurface be level zero maybe to create building automatic on
Message 4 of 8
Sure. Lower the Toposurface AND Survey Point together.
Message 5 of 8
Set your Project's Contour Labels to the Survey Point.
Message 6 of 8
mohiroal
mohiroal
thanks for your patience ,can you please explain by steps
Message 7 of 8
Steps? Go to Elevation View, turn on the Toposurface and Survey Point Categories, select the Toposuface and Survey Point and drag them both down however far they need to be from the building Levels. Obviously, you'll need to make that judgement. I wouldn't know how far.
Message 8 of 8
Is this Project for Architectural Planning or Site Planning?  I don't see any buildings in it.  Are you linking buildings into this Project?  If so, leave the Topo and Survey Point where they are at and instead raise the Links in Elevation/Section View.
