I have the same wall on 2 different levels. There is a reveal that spans both levels. On the upper level where the reveal is the material is a darker color. The lower level where the reveal is located is the same color as the wall.
How do I get the lower level reveal to have the same dark brick color as the floor above?
-Ian
Solved by Ian_H. Go to Solution.
When trying to get a portion of the model into a new file so I wasn't posting a huge file I figured it out.
