Finish Edit Mode
Finish Edit Mode
Finish Edit Mode
Whenever I go to complete an extrusion, etc., and if I don't have the lines connected or if they are overlapping, it doesn't tell me there is an error like it used to so I can't see where to fix the line work to close the loop.
Please help on getting that back to be able to locate where the loop is open etc.
Did you change monitor configuration / resolution lately? Plug in an additional monitor and/or change resolution see what next.
Yes I did, how do I change that back?
I am just on my laptop now though without the other monitors.
djthompson
it maybe off screen.
Use Winlister to check and bring it to centre.
Run winlister first so you can see a new window appearing when you finish edit.
Karol_Piroska
Uninstalling RevitInfraWorks fixed the update. Thanks for the link to the forum!
