Finding Family File Location on Computer from Revit
calarson
Observer Observer
calarson
Observer
Observer
I want to select a Revit family already in the model and get a file path map of where on my computer its being loaded from, is that possible?
David_W_Koch
You could select an instance of the family (or find the family in the Project Browser), right click and choose Edit.  With the family open, choose the Save As option on from the Application Menu (big "R" in upper left corner) and see where the initial default save location is.  If that family already exists there, that is likely the version that was loaded into the project.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
CVDemick
Is there a way to break the stored file path from the family in your project? We are starting to do jobs in a more current version of Revit and I am worried that someone will open a family that is in our template, edit it and save it back to the network drive where it is stored. If they do this in a newer version of Revit the family cannot be used in older versions anymore.
RobDraw
Make the library read only to prevent accidental overwriting.
Rob
michael.coviello
Autodesk Support
Autodesk Support
Hello @CVDemick ,
I came across this post today.   I understand it's been a long while since your post but wanted to share this information which might help understand the behavior more and how to force a new path if needed.
Family Reload... opens the wrong directory from where the family is saved in Revit
Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
Michael C
Technical Support Specialist
What's New in Revit 2023 | Autodesk University | Revit Blog
CVDemick
@michael.coviello , in order to keep our families from being inadvertently upgraded we have changed the double click options for families and set it to "do nothing". This keeps users from accidentally opening the Families. We also keep good back ups of our standard families just in case something goes wrong.
michael.coviello
Autodesk Support
Autodesk Support
Hi @CVDemick
Thank you for sharing the double click option.
I am checking back to see if my post or others helped you with your problem.
Michael C
