Revit 2015 ACAD links
mpukas
mpukas
I typically set up a project with two models - a building model and a site model - and then link them together. In the site model, I link in an ACAD DWG from my surveyor. Then, when I link the site model into the building model, the ACAD DWG link will be brought into the building model, and I didn’t have to link the survey into the building model directly.
However, on a current project, the ACAD DWG link from the site model is not showing up in the building model (Revit 2015).
I've done everything the same as my other projects. Is there something I'm missing? Is this a new feature/setting in 2015. Thanks. mpp
mpukas
Found it - Visibility graphics, RVT links, import categories. I knew I was missing someting that was right in front of my face.
