Filters, material take-off and 3D views
lm4
Message 1 of 9
lm4
Hi all, does anyone know if i can combine a filter to a 3D view by material takeoff?
My revit materials have some parameters, and i am able to filter by those parameters in schedules ( material take-off schedules) BUT i would like to be able to filter in a 3D view by the same material parameters ( basically to have a 3D view where i can show only specific materials). Is this even possible in Revit?
Replies (8)
Message 2 of 9
l2vrevit
Community Visitor
Community Visitor
Check this option in filters, in table settings.
So when you place the 3D view on a sheet, it will only calculate the quantities of that 3D view.Captura de tela 2024-01-23 095445.png
Message 3 of 9
There might be a way to write a Rule-Based Filter. For instance, you could add a Rule-Based Filter to the 3D View that would hide all the Walls that do not have a particular Structural Material. You could filter by a Project Parameter assigned to Categories, but you would need to input the values manually.  Parts might get you there as well.  Part's Material is a rule you can filter by in a Rule-Based Filter.
Provide some more information about these Material Parameters you are talking about.
Message 4 of 9
lm4
Hi, i do not have that option in my schedule, could it be because it s a Material take off schedule?
Message 5 of 9
lm4
the thing is i have all my parameters that i would like to filter by, but they are all connected to the actual revit material, not element categories.  In my 3D view i can see all the categories, but there s no option in filters for 3D view to filter by materials and other parameters. That is why i wondering how i could connect the 2 ( schedule with Material take off and  a 3d  view)
Message 6 of 9
lm4
i am unsure why i cannot see the same option as you?
Message 7 of 9
lm4
got it, this option is available for revit 2023 and i still use revit 2022 🙂
Message 8 of 9
If I understand correctly then Filter by sheet is the reverse of what you want.  It is to filter a schedule based on the visibility of a view, but not filter what to be shown in a view.
Message 9 of 9
Still don't have enough information from you about the specific criteria.  Like I said, it may be possible. All depends on the specific criteria.
