Filter doesn't work with comments (Instance) - Revit 2020.2
r.fourdain_RBA
Message 1 of 9
r.fourdain_RBA
Hi everyone,
I would like to create 3D views in Revit 2020.2 that use a comment (Instance) based filter.
Unfortunately, this doesn't work.
I have already tried different rules, but still without success...
Is this problem known?
@Anonymous
Replies (8)
Message 2 of 9
amarkonathala
I didn't get you, u would like to group or View schedule as like below
Message 3 of 9
Are you talking about Rule-Based Filters? Did you actually add the Filter to the 3D View?
Message 4 of 9
r.fourdain_RBA
Good morning everyone,
thanks for your Answers.
Yes I'm talking about Rule-Based Filters to check in 3D View all my Elements whom have comments.
I have used exactly the same Rule-Based Filter but with an shared parameter as Instance and it's working.
If one Element has a comment, I can see it in my 3D view.
If not are my Elements whitout comment hidden.
BUT with standard parameter "comment" from Revit it's still not working.
Message 5 of 9
That's not possible. Sounds like someone may have added a Shared Parameter/Project Parameter named "Comments" to the Project.  How many "Comments" do you see?
Message 6 of 9
amarkonathala
The Default parameter is likely to be Comments not comment
Yeah can use that one to create filters in any View
Message 7 of 9
SM_RSoucie
i am trying to figure out how to do this too, we have "comments" set as piping systems, how would i isolate based on those comments so i can export isolated piping systems to cad?
Message 8 of 9
Add Comments = Not Equal: the value of the pipes you want to isolate. Then add the filter to the view/view template and clear the Visible box.
Message 9 of 9
SM_RSoucie
ok it looks like that worked, i did the complete opposite. i had the filter "equal" the "comment" we wanted then selected the "visible" box for it
